# Automatically-generated file. Do not edit!
SHELL := cmd.exe
RM := rm -rf
USER_OBJS :=
LIBS :=
PROJ :=
O_SRCS :=
C_SRCS :=
S_SRCS :=
S_UPPER_SRCS :=
OBJ_SRCS :=
ASM_SRCS :=
PREPROCESSING_SRCS :=
OBJS :=
OBJS_AS_ARGS :=
C_DEPS :=
C_DEPS_AS_ARGS :=
EXECUTABLES :=
OUTPUT_FILE_PATH :=
OUTPUT_FILE_PATH_AS_ARGS :=
AVR_APP_PATH :=$$$AVR_APP_PATH$$$
QUOTE := "
ADDITIONAL_DEPENDENCIES:=
OUTPUT_FILE_DEP:=
LIB_DEP:=
# Every subdirectory with source files must be described here
SUBDIRS :=
# Add inputs and outputs from these tool invocations to the build variables
C_SRCS +=  \
../main.c \
../USI_TWI_Master.c
PREPROCESSING_SRCS +=
ASM_SRCS +=
OBJS +=  \
main.o \
USI_TWI_Master.o
OBJS_AS_ARGS +=  \
main.o \
USI_TWI_Master.o
C_DEPS +=  \
main.d \
USI_TWI_Master.d
C_DEPS_AS_ARGS +=  \
main.d \
USI_TWI_Master.d
OUTPUT_FILE_PATH +=AVR310\ Using\ the\ USI\ module\ as\ a\ TWI\ master.elf
OUTPUT_FILE_PATH_AS_ARGS +="AVR310 Using the USI module as a TWI master.elf"
OUTPUT_FILE_DEP:= ./makedep.mk
LIB_DEP+=
# AVR32/GNU C Compiler
./main.o: .././main.c
	@echo Building file: $<
	@echo Invoking: AVR/GNU C Compiler : 3.4.2
	$(QUOTE)C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE)  -funsigned-char -funsigned-bitfields -DDEBUG -DF_CPU=4000000UL  -O1 -ffunction-sections -fdata-sections -fpack-struct -fshort-enums -g2 -Wall -mmcu=atmega169pa -c -std=gnu99 -MD -MP -MF "$(@:%.o=%.d)" -MT"$(@:%.o=%.d)" -MT"$(@:%.o=%.o)"   -o "$@" "$<"
	@echo Finished building: $<
./USI_TWI_Master.o: .././USI_TWI_Master.c
./%.o: .././%.c
# AVR32/GNU Preprocessing Assembler
# AVR32/GNU Assembler
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
endif
# All Target
all: $(OUTPUT_FILE_PATH) $(ADDITIONAL_DEPENDENCIES)
$(OUTPUT_FILE_PATH): $(OBJS) $(USER_OBJS) $(OUTPUT_FILE_DEP) $(LIB_DEP)
	@echo Building target: $@
	@echo Invoking: AVR/GNU Linker : 3.4.2
	$(QUOTE)C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-gcc.exe$(QUOTE) -o$(OUTPUT_FILE_PATH_AS_ARGS) $(OBJS_AS_ARGS) $(USER_OBJS) $(LIBS) -Wl,-Map="AVR310 Using the USI module as a TWI master.map" -Wl,--start-group -Wl,-lm  -Wl,--end-group -Wl,--gc-sections -mmcu=atmega169pa
	@echo Finished building target: $@
	"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O ihex -R .eeprom -R .fuse -R .lock -R .signature  "AVR310 Using the USI module as a TWI master.elf" "AVR310 Using the USI module as a TWI master.hex"
	"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -j .eeprom  --set-section-flags=.eeprom=alloc,load --change-section-lma .eeprom=0  --no-change-warnings -O ihex "AVR310 Using the USI module as a TWI master.elf" "AVR310 Using the USI module as a TWI master.eep" || exit 0
	"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objdump.exe" -h -S "AVR310 Using the USI module as a TWI master.elf" > "AVR310 Using the USI module as a TWI master.lss"
	"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-objcopy.exe" -O srec -R .eeprom -R .fuse -R .lock -R .signature  "AVR310 Using the USI module as a TWI master.elf" "AVR310 Using the USI module as a TWI master.srec"
	"C:\Program Files (x86)\Atmel\Atmel Toolchain\AVR8 GCC\Native\3.4.2.1002\avr8-gnu-toolchain\bin\avr-size.exe" "AVR310 Using the USI module as a TWI master.elf"
# Other Targets
clean:
	-$(RM) $(OBJS_AS_ARGS) $(EXECUTABLES)
	-$(RM) $(C_DEPS_AS_ARGS)
	rm -rf "AVR310 Using the USI module as a TWI master.elf" "AVR310 Using the USI module as a TWI master.a" "AVR310 Using the USI module as a TWI master.hex" "AVR310 Using the USI module as a TWI master.lss" "AVR310 Using the USI module as a TWI master.eep" "AVR310 Using the USI module as a TWI master.map" "AVR310 Using the USI module as a TWI master.srec"
